 Ultra Stick 40 Setup Question >
Old 08-24-2006 | 09:29 PM
Default Ultra Stick 40 Setup Question
I just got a ultra stick 40 for a toss in the car and go fly plane. I have it set up with the quad flaps on my 8UA (non-super). Everything is done as per the manual using the glider programming. All seemed fine till I advanced the throttle with the crow activated. As the throttle increased the amount of crow decreases. Is it supposed to be this way? I have tried eveything to get it to stop. There is no mention of this in the manual. Am I missing something?
Old 08-24-2006 | 10:46 PM
bl3ck's Avatar
Default RE: Ultra Stick 40 Setup Question
I have the 9c and do not no about the 8ua but maybe you should post this question in the futaba support forum or try this link http://www.futaba-rc.com/faq/faq-8u-q177.html hope this helps
Old 08-24-2006 | 11:30 PM
This is just how it works on the 8U and 8U super when you use the glider mode.
The 8U manual eludes to being able to set it up without using the programmed mixes, I messed with mine a little bit and gave up on it.
If you figure it out post the setup.
Old 08-25-2006 | 12:51 AM
one thing its not a glider and next the crow as you refer to it is used on gliders as a spoiler or air brake to incress lift
Old 08-25-2006 | 06:35 AM
Thanks for the replies. I know it's not a glider. I just followed the instructions in the ultra stick manual which says to set it up as a glider and that the throttle will function normally. I'll have to play with the mixes a bit.
Old 08-25-2006 | 06:59 AM
It's a good suggestion to take the problem over to the Futaba forum.
Old 08-25-2006 | 07:56 AM
I just posted the same question on the futaba forum. You can close this thread if you wish.
Old 08-25-2006 | 09:44 PM
My ultra stick and others as well do this with the futaba 8uafs radio. Think of it as a go-around mode as you throttle up to get out of trouble. It appears to be normal with the 8u radios.
