RCU Forums - View Single Post - Rudder Pull-Pull.... what is the best equipment?
Old 08-25-2006 | 04:18 AM
Rate1's Avatar
Rate1
Default RE: Rudder Pull-Pull.... what is the best equipment?
Ok. Do you guys know of any other pull-pull that is not as heavy as the Dubro is? I have used the Dubro earlier on my Extra 300 .60 and it worked great. However I have always thought that the bult boing thru the rudder is a heavy piece being made from steel. Also Im now in the start up for building a 1/4 scale Extra and would like it to as light weight as possible.
