RCU Forums - View Single Post - Rudder Pull-Pull.... what is the best equipment?
Old 08-25-2006 | 06:21 AM
pettit's Avatar
pettit
My Feedback: (23)
Default RE: Rudder Pull-Pull.... what is the best equipment?
You could use 2 control horns back to back with bolts between them. But that may weigh about as much as the Thru-bolt type.
When you reduce weight, sometimes you sacrifice strength too.
Maybe a piece of epoxy glass printed circuit board cut to size and glued into the rudder structure?
Carbon fiber?
You can go as far as your pocketbook can take you.
