RCU Forums - View Single Post - 3D Hype
Thread: 3D Hype
Old 01-08-2003 | 01:45 PM
kris1
Default 3D Hype
A friend of has bought the Flair Giles 3 D. It cost £118. Take a very careful look at it though because it will need some reinforcement. The rudder is all flying with no fin. And is held on with two cyno hinges. The rudder is built very light. The fire wall will need to be reinforced with some tri stock, and the fuz its self will need some type of reinforcement as it will twist laterally with the wing off. The wing mounts on the top of the fuz and a moulting is is used for the canopy etc. The gustimate is under 4lbs with the YS 63 ready to fly. At this weight a good 36 will be an option. I will keep you posted as to how ir goes.
Kris
