RCU Forums - View Single Post - Ultrastick 40 setup problem
Old 08-25-2006 | 01:56 PM
Bax
Default RE: Ultrastick 40 setup problem
In glider mode, Crow is tied to the throttle stick. You need to use a switch to turn that mix on and off. Then you can have the crow function on only when you want it, and not tied to the throttle all the time. If you do want it tied, you should set the movements up so that the crow feature is fully-off when at full throttle.
