Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Ultrastick 40 setup problem
Old 08-25-2006 | 07:55 AM
Default Ultrastick 40 setup problem
I just got a ultra stick 40 for a toss in the car and go fly plane. I have it set up with the quad flaps on my 8UA (non-super). Everything is done as per the ultra stick manual using the glider programming. All seemed fine till I advanced the throttle with the crow activated. As the throttle increased the amount of crow decreases. Is it supposed to be this way? I have tried eveything to get it to stop. There is no mention of this in the manual. Am I missing something?
Old 08-25-2006 | 01:56 PM
Bax
Default RE: Ultrastick 40 setup problem
In glider mode, Crow is tied to the throttle stick. You need to use a switch to turn that mix on and off. Then you can have the crow function on only when you want it, and not tied to the throttle all the time. If you do want it tied, you should set the movements up so that the crow feature is fully-off when at full throttle.
Old 08-25-2006 | 02:04 PM
Thanks for the reply
Right now as set up the crow mix is activated by switch A. When it is activated the throttle affects it. When the crow is off the throttle functions normally. The question is can the crow be turned on (flaps down and ailerons up) and not be afftected by throttle change? Can the portion of the mix that mixes throttle with the crow be turned of separately?
Old 08-26-2006 | 03:40 PM
go to futaba fag section . there is another way use the aircraft menu .
