RE: Ultrastick 40 setup problem
Thanks for the reply
Right now as set up the crow mix is activated by switch A. When it is activated the throttle affects it. When the crow is off the throttle functions normally. The question is can the crow be turned on (flaps down and ailerons up) and not be afftected by throttle change? Can the portion of the mix that mixes throttle with the crow be turned of separately?
