ORIGINAL: specracer
lol who said enything about a car lifting up on one side..if a cars motor is sitting from front to back then its car is going to twist a little even if you cant tell.
I found it on post number one. BTW, it's called a longitudinal mounted engine. A transverse mounted engine would not do this to a large extent.
This is the original post by the author of this thread
on my truck its so bad that when i gun the throttle , the left side lifts off the ground and the car veers left
From this I figure his car is lifting completely off the ground on one side. Whether it is the drivers side or passengers side I'm not sure. I don't know how else to clearly explain this to you or am I the only one who actually read it.
Ryan
