RE: Not Your Common Interference Problem
Try wrapping the spark plug lead and the spark plug with aluminum foil. Ground the foil firmly to the engine at the spark plug. If that helps get a Bosch spark plug cover from C&H.
If you replaced the spark plug make sure the sales clerk didn't slip you a non resistor plug.
Take the C&H system off the US41 and try it on the Quadra. If it fixes the problem get rid of the mag
