ORIGINAL: WHMC
Sir, Looks like you screwed on the canopy. Glue will work? The canopy, as delivered had no lines , for cutting. I cut mine and it happened to be short , as it would not reach the canopy band! Cut off the band and it looks like a Bandit? What do you think. WHMC
for the canopy:
i put the canopy over the frame , drawed a line where to cut.
then cutted 1/2 centimet shorter and it fitted.
i did not use glue in the beginning because of the not so perfect fit of the canopy glass.
