ORIGINAL: Dave Wilshere
Guys
Just finished a so so weekend flying the Flash at the British Nats show line, poor organisation this year made it hard to get a flight, so I only managed 5 flights in the two days.
One possible problem I will speak with Comp ARF about is that the retract/oleo pins were very hard and hence brittle.
I had a fast/messy landing on Saturday and braking harder than I would have liked skidded the aeroplane side ways on a very grippy runway surface and a pin snapped.
Only a tiny mark on the wing and tail tip as it was nearly stopped.
Looking at the pin which only took five minutes to replace it is very hard material. I replaced mine with 6mm silver steel which will give slightly.
This is worth looking at for anyone with the stock gear.
Dave Wilshere
be carefull if they give to much you could rip out the formers.
we experimented a lot with this sort of steel and even harder steel.
