RE: Fuel Dot
I want to add that if you use a 2 line system with a fuel dot, make sure you put an inline filter between the T connector and the engine. The reason is you are pumping fuel in that could contain trash. This is especially important if you rely on a filtered clunk as you will have fuel in the line that never gets filtered by the clunk.
