RE: Comp ARF Flash update
Thanks Bob, that is the plan for now.
David are you using the C-36 retracts with the included components? I am a bit leary to run a one tank system but the gear kit looks very nice and well thought out. Have others used it this way? I will add a pressure gauge either way.
Sandor, can you post an installation photo of the Wren augmented pipe please? Any heat issues and did you cut out the NACA air inlets on the rear bottom of the fuse?
JOe !~)
