RCU Forums - View Single Post - Comp ARF Flash update
Old 08-30-2006 | 03:19 AM
  #185
digitech
My Feedback: (10)
Default RE: Comp ARF Flash update
ORIGINAL: Goekeli
Thanks Bob, that is the plan for now.
David are you using the C-36 retracts with the included components? I am a bit leary to run a one tank system but the gear kit looks very nice and well thought out. Have others used it this way? I will add a pressure gauge either way.
Sandor, can you post an installation photo of the Wren augmented pipe please? Any heat issues and did you cut out the NACA air inlets on the rear bottom of the fuse?
JOe !~)
no heat issues
i used the outer tube from c-arf for the heat protection.
the inner pipe is now connected to my tool shed , and is doing a fantastic job as a stainless steel rain pipe , considering its weight it will hang there forever.
what naca inlets? just did not do anything, i missed something?
the pipe fits perfect just ask sara to get you normal size one
if you need the exact size i can measure it up for you.
by using this system all the air can pass right thru and cool the fuselage.
you really can feel anything as the engine runs.
turn the engine off and the temp rises a bit.
