Bev,
No pattern and IMAC are different.
Under IMAC, the only limitation is that the plane should be a scaled version of a full scale plane that is used in aerobatic competition. Under Pattern, there are limitations on the weight of the plane (11lbs) and the wingspan of the plane (2 meters).
We use the same language and maneuvers but the rules for flight is different.
ORIGINAL: Skyhigh Bev
ORIGINAL: PatternPilot
Hi Bev,
Think about the pattern crowd... would love to have a female on the SE pattern scene....
Scott Anderson
Team Tanicpacks.com
Team Castle Creations
PatternPilot, Is pattern the same as IMAC? Do you compete? If so, what type and size planes?
Bev
