RCU Forums - View Single Post - Tools to use for making panel lines
Old 01-10-2003 | 10:30 AM
Slug
Default Another option.
Greg,
I have always been nervous about cutting into the surface with a tool of any kind, it seems to me that this would produce weak spots in the covering.
I have used the tape method explained above, however I now prefer the following:
1. Stick some masking tape on your wing with the edge on the panel line.
2. Apply a very thin smear of filler up against the edge of the tape.
3. Sand (I use fine wet & dry, used wet) to blend the filler into wing surface.
4. Remove the tape, to be left with a raised edge to your panel.
The picture shows the results on my Royal Bearcat.
Simon.
