RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 09-02-2006 | 06:44 PM
  #308
EASYTIGER
Banned
My Feedback: (119)
Default RE: Nitro models pusher Bobcat?
ORIGINAL: mugenkidd
yeah, I think thats enough French bashing, should be against RCU rules... anyway English is obviously his second language, and the truth of the matter is Turbine power is in no way similar to prop power, but adding the weight to the plane(of a bigger engine) can be an advantage if your looking for clues in helping with a turbine upgrade.
I must say I think a Jett engine would be a good choice also, this plane needs a high RPM engine. From my experience the zinger props aren't very effiecient, and a 3-blade prop will just lower effieciency (in a model anyway)... well good luck to everyone. And can we please keep from bashing others. RCU is not a means to voice your political opinions.
You noticed that, too? The Zinger props are lame. So are the Master Airscrew. The APC is lightyears ahead, really a big difference. Not sure what APC makes in the way of pushers...finding the right props is a big deal with pusher engines...on my last pushers, a Republic Sea Bee and a Saab J-21, I ended cutting down larger pusher props by hand and re-balancing them to get better performance.
