RCU Forums - View Single Post - Attatching landing gear on SIG Wonder?
Old 07-19-2002 | 10:05 AM
dr_wogz
Default Attatching landing gear on SIG Wonder?
I've built a few of these. Even tried a twin (Don't bother..)
As for landing gear, one critical piece is missing.. Rudder! Unless you plan to add a rudder (servo at least), and beef up where you intend to add the tail (or noze) wheel. You'll need to add a hard wood or ply block to mount the main Landging gear. You'll be adding a bit of weight. You might have a bit of a problem fitting the tank afterwards..
As for flying, probably will fly just the same, it'll just be a tad heavier, and a little more drag..
Typically, main wheels forward of the CG for a tail dragger, and main wheels behind teh CG for a trike set up. Make teh mains as wide a possible, and high enough to not get a prop strike. Use a screw on metal (or plastic/carbon fiber) one piece design for the mains.
best of luck!
