ORIGINAL: wilerbee2
Well,
I maiden-ed mine today and it flys fine. CG is at 9and 1/2 inches and still a tad nose heavy but otherwise OK. Next flight will try 10 inches. I powered mine with a China made outrunner brushless on a 3 blade 12 x 6 prop with a 5s1p 4000mah battery pack. Enough power for my style of flying but a bit slow for speed demons. The main gear being so far back from the CG did not allow the plane to ROG without elevator input, but once elevator is pulled it leaps into the air. However, this layout did allow me to have a super smooth landing and once on the ground the plane did not have any tendency to bounce. I did tend to come in a bit hot though !! Hope all of you that have this kit to have as much fun as I did !!
To clarify between the Point of balance or the Neutral point and the CG.
If your models point of balance is at 9 1/2" and it flies nose heavy, This tells you your NP is further forward. If the CG of your airframe is 10" and you are trying to balance at the CG then you are even more nose heavy than at 9 1/2" considering not moving any weight around. If you move weight further back from the nose from a balanced aircraft, your NP will be aft.
Here is a useful diagram to help.
