RCU Forums - View Single Post - Cp Pro Problems!
Old 09-03-2006 | 06:33 PM
cooperd
Default RE: Cp Pro Problems!
ORIGINAL: Psikelly
Oh btw, I know you havent said your frame is broken but if your Boom is broken themn you may as well do the frame because they come as a set and its just easier than trying to get the boom out of the old frame. Then when you have time to screw around you can always fix up your old frame.
Actually it's quite easy to get the boom out of the frame! After you strip all the stuff from the frame, but the broken boom close to the frame. Get some acetone (hardware store) and soak the end of the frame containing the now cut off piece of boom. In about 10 minutes or so it will come loose. For about $4 or so you can buy some stock carbon fibre rod that is more than long enough to make a new boom. Now you have a spare frame for the next time. So yes, the quickest repair is get a new frame, and repair the old when you have some time.
