RCU Forums - View Single Post - CEN Mt2 flooding
Old 09-04-2006 | 06:58 PM
mulletman
Default CEN Mt2 flooding
I was just getting my truck out for my Labour day bash. The truck will not stop flooding, the high speed niddle is 2 1/2 turns from flush. The truck will start on the first pull and then die. The idle gap is about 1 1/2 mm from closed. I can kink the fuel line and the truck will stop flodding, then will fire on the next pull and die. I had the truck started but i couldn't get it the move it would just die if i gave it throttle. This happend before and the idle gap had closed and it was sucking fuel. This same problem seems to happen when ever i take the motor out. Do you have any idea what is wrong?
