RCU Forums - View Single Post - Venus II
Thread: Venus II
Old 09-05-2006 | 02:07 AM
  #141
Nickolas's Avatar
Nickolas
Default RE: Venus II
Hi guys,
Venus (Jini-S)is finally ready to go, I just need to install the cowl and check some minor things. The plane balances ok with the YS-140 FZ which is a beast in terms of power but not weight. Battery has been located just behind the recommended Rx position. Tank is located at the CG region.
My setup is as follows:
- Engine YS-140 FZ turning an APC 15x12 prop with std muffler set
- Gator Soft Mount
- Tetra 16 oz high pressure tank
- JR NES-4131 on elevator and ailerons, JR NES-4721 on Rudder, JR NES-321 on throttle
- JR 10ch PCM synthesized Rx 10DS and JR heavy duty switch
- JR 1400 mAh NiCd
- Sullivan 4-40 pushrods everywhere I did not trust that soldering illustrated in the manual.
It seems very promising and now that has been assembled I like it more, let's hope that it will fly as good.
Nick
ID:	519194   Click image for larger version
ID:	519195   Click image for larger version
ID:	519196   Click image for larger version
