RCU Forums - View Single Post - Typhoon troubles!
Old 09-05-2006 | 12:27 PM
woodymaxx's Avatar
woodymaxx
Default Typhoon troubles!
My motor cuts out in flight. then once I get it to the ground. it resets. its really anoying. I am figureing its a short in the motor wiring because the servos and radio still work all the time. Anyways so I tested the wires on the esc. and there fine. but the wires on the motor are what it has to be because the yello one got the sheilding cut a little during the last crash. I thought it would be find and kinda sealed it. but I guess not. how do you take the motor apart to re wire it? or what else would make the motor cut out. what it does it will be going for a random amount of time for the most part and then make a grinding noise for a split second and stop.... weird. It used to just do that when I would give it throttle when the prop was stopped or I had tottally let off. It would make I grinding noise for a split second and then go... does everyone elses do that?
