RE: Help needed
Not sure, it might. Not worth the risk if you ask me. If you have a 6 channel Transmitter and receiver you can just use a servo on the landing gear/retract switch (channel 5 or 6 depending). Attach the servo to some make shift "Bombay" doors via a coupler and piano wire or something of that nature, or you could go without doors that open and close and make some kind of pin release or something when you trigger the switch.
