Does the 14 MZ Receiver work with a base loaded antenna
Question, Does the 14 MZ Receiver work with a base loaded antenne such as what is flown on the jets that I have seen, or on IMAC planes.
The antenna wire is usually cut to a 4 inch long length and then attached to the short whip antenna. I have seen them laying parallel inside airplanes and contained with in the fuselage.
What works? And if so what is the recommended antenna?
Thanks to all who respond.
Dan
