Emvin that is about avg. as the weight. Mine weighted in around 14 close to 15lb. I had to add weight to the nose
ORIGINAL: EMVIN
OK It weighed in at 12lb 14oz....That seems a little heavy.....However the saito 220 has something to do with that...It balanced perfectly at 3.5" back from the leading edge. there is a 6volt battery mounted just behind the fuel tank....Any comments ????? Feedback Please!!!!
