RE: How do you remove the Clutch Gears?
Put the clutch bell in the oven at around 500 degrees for a couple of minutes or on the stove top burner to heat it up really well. You could also use some form of torch to heat it up as well. Keep in mind that it will be incredibly hot and you will need to hold it with pliers while you take it off.
rolland
