RCU Forums - View Single Post - Why do the flaps hang down when the plane is off?
Old 09-08-2006 | 10:27 PM
bigtim
My Feedback: (13)
Default RE: Why do the flaps hang down when the plane is off?
also the ailerons have separate servos so there not connected like most trainers with single servo setups and can sag when the power is off . having a servo for each aileron gives more control authority . that plane in the foreground has a DA 150 which is a 2 cilinder gas engine which means there are probably 2 servos on each surface in the wing and 2 or 3 servos on each of the other surfaces with a pull-pull set up $$$$$$
