RCU Forums - View Single Post - DX6 setup for Blade CP
Old 09-09-2006 | 11:25 AM
Gonwee
Default RE: DX6 setup for Blade CP
ORIGINAL: drphoto
Psi,
thanks for posting that. Do you you have any info on the 'receiver hack' or how to make the physical electronics work? I have a std. BCP. With the Spektrum receiver, do I need to change to a 3n1 to get tail mix, gyro and motor?
btw: you got me inspired. working on my own paint job now. will post a pic when finished.
If you don't have an external gyro, then you will need the 3-in-1, and if your using the stock motors.
If you have a 4-in-1 then its possible to change it and put wires on the connections between the 3-in-1 and the reciever, you need to be good with a soldering iron to do this it requires soldering to the board, You can take the 4-in-1 apart and you'll see its just 2 halves connected by the 3rd and 4th channel. theres a block on the back of the 3-in-1 that needs to be removed so you can solder where it was.
If you have an esc for the main, and tail motors. And a gyro you don't need the 3-in-1, you just use revo mixing on the transmitter, unless you have a hh gyro, then you don't need any mixing.
