RCU Forums - View Single Post - blade cx problems
Old 09-09-2006 | 01:13 PM
buttonboy
Default blade cx problems
Hey, I need some help. I had a little spill with my blade cx and had to replace the blades and the inner main shaft (the shaft the upper blades connect to) I put it all back together, i bought upgrade shaft that has the aluminum top piece where the stablizer mounts, and tried to hover, but every time the cx gets almost off the ground it tips forward and to the left. I've adjusted everything I can think to adjust except the motor trimmer. It hovered fine beforehand, i can't imagine that the motors need to be adjusted. Does anyone have any ideas on what i need to do? Thanks so much for any help you can give.
