RCU Forums - View Single Post - GT brake help
Old 09-09-2006 | 02:45 PM
AJ DRAGON
Default RE: GT brake help
ORIGINAL: dannthenitroman
no, us racers use stock, i tried the cr system, its ok but not as good as disk, go with the stock ft gt disk and a better servo, say 100 + oz/in.
Dann
Hi
You must not have had the CR Brake set properly, because the one that is on mine works allot better then the AE disk, and that is with a stock Futaba servo. It works so good that I can lock up the rear tires, something I could never get the disk to do.
