RCU Forums - View Single Post - SEAGULL EP Extra 300
Old 09-09-2006 | 11:01 PM
Get Real's Avatar
Get Real
Default RE: SEAGULL EP Extra 300
im very pleased so far with the fit and qaulity of this plane. theres some minor concerns but flying and time will tell. this plane has very little left to assemble and should go together in about an evening when i have time. theres a nice instrument panel applied in cockpit and theres no need to glue canopy down its already secured from the factory. the battery mounting is a little different.. theres a tray system to install battery in plane/i'll probally modify this later for easier use. the landing gear seems rather strong and the wingtube is made of metal.. these are two areas you could probally cut down on weight if needed. i plan to set it up by the manual and later add a tail wheel and make changes or modifications as needed for my type of flying.
ID:	521726   Click image for larger version
ID:	521727   Click image for larger version
ID:	521728   Click image for larger version
ID:	521729   Click image for larger version
ID:	521730   Click image for larger version
ID:	521731   Click image for larger version
ID:	521732   Click image for larger version
