RCU Forums - View Single Post - ch ignition problem
Old 09-10-2006 | 09:42 AM
tim220225's Avatar
tim220225
Default RE: ch ignition problem
Take the plug out and make sure it is grounded. Turn the ignition on. You may get spark. Now turn the engine over so the magnet passes the sensor. After the magnet passes there should be spark. If not the sensor is bad. You have to have the system grounded. Otherwise you will blow the sensor.
