RCU Forums - View Single Post - Cnc knuckle for lx comp2?
Old 09-10-2006 | 10:13 AM
hopup king
Default RE: Cnc knuckle for lx comp2?
Yes you bought the right ones and yes they need to be shimmed. The knuckles should have came with 2 shims. Put 1 shim on the end of the universal before you install it into the knuckle this will align the universal so it does'nt pop out and it will remove all of the play in the drive system. Use 1 shim on each knuckle and you should be good to go.
