RCU Forums - View Single Post - Brio with a DEPS
Old 09-10-2006 | 04:11 PM
KeithB's Avatar
KeithB
Default RE: Brio with a DEPS
I forgot to mention:
1. Swapping out the rudder is a very good idea, the stock one is way too heavy and I've heard of cases where the hinge has cracked. It also makes it much easier setting up the DEPS system and a tail former if you choose to add one.
2. Two of the pictures included above show the technique I use to help find the exit holes for the DEPS system (also works for pull-pull).
I've attached some pics of my ruder build.
Keith B
ID:	522053   Click image for larger version
ID:	522054   Click image for larger version
ID:	522055   Click image for larger version
ID:	522056   Click image for larger version
ID:	522057   Click image for larger version
ID:	522058   Click image for larger version
