RE: SeaStar Test Flight
Ed - Why did you have to hold rudder the entire way when you had one engine out? I thought that your technique of having engines set at 8 degrees outthrust (each) was to overcome this need. Didn't you have this outthrust set up? You may recall that we exchanged emails on this with regards to the 104" WS PBN Nomad I have under construction now.
