RCU Forums - View Single Post - Difference Between RB C6 and S7WIII
Old 09-11-2006 | 02:18 PM
sh0wtime's Avatar
sh0wtime
Default RE: Difference Between RB C6 and S7WIII
the C6 is a long stroke engine with MES (multi Exhaust System) basically 1 main & 2 smaller exhaust ports
the WS7 engines have a "square" configuration where the bore is the same as the stroke & in "theory" should be higher revving engine although this isn't always the case likewise the longer stroke engine should produce more torque
venturi size, state of tune & pipe selection will have more of a deciding factor over the above variables anyway
