ORIGINAL: Advent
Did you install some plywood backer or a bulkhead behind
the servo's in the fuse?
Yes, I glued in some small 3/32 aircraft ply doublers (don’t use lite ply as it doesn’t hold the screws as well.)
Wish there was a way to adjust them like the MKs.
The nice thing about these homemade horns is you have lots of opportunities to custom fit them to match sides where as once you drill the hole for the MK, you’re committed (in terms of being parallel and the same distance from the hinge line.) BTW, credit for these goes to Checksix!
