Zimmerit is an anti magnetic mine coating,applied to vertical surfaces of the tank, you should have 'stick on' zimmerit sheets with your kit, or you can make your own with various modelling 'pastes' or forget the zimm coating altogether.
Bearings , can't help, but mine works fine without.
It's a good idea to at least prime the metal parts before assembly.
Hope this helps some.
