RCU Forums - View Single Post - Hiding the antenna
Old 01-11-2003 | 06:51 PM
SigFan
Default Hiding the antenna
I run mine inside a leftover length of goldenrod or similar material and place them inside the fuse. Try not to run it too near the servos and hold in in place with a couple of drops of CA. Just be sure to do a range check before your first flight, I've not had a problem to date with this setup.
Good luck.
