RCU Forums - View Single Post - Hiding the antenna
Old 01-12-2003 | 03:10 AM
strato911
Default Hiding the antenna
Originally posted by SigFan
I run mine inside a leftover length of goldenrod or similar material and place them inside the fuse. Try not to run it too near the servos and hold in in place with a couple of drops of CA. Just be sure to do a range check before your first flight, I've not had a problem to date with this setup.
Good luck.
Just for clarification, I assume SigFan means to use a couple drops of CA to hold the goldenrod tube in place. I would never use CA directly on the antenna.
