ORIGINAL: Spartan-Drifter
tt-01d just comes with the prop shaft and drift tires
No it doesn't!! Do your homework before posting a comment like that!
The TT01 Spec:
Oil Filled Shocks (CVA unit) w/Red Springs
Sport Tuned Motor
Alu. Motor heatsink
Adj. upper arm set
Bearing set
Drift Tires
And the susp. arms are not standard, the lower arms have settings where (if you read the manual) you can mount the stabilizer sets lower and adjust the rebound rate, they are the same as on the TT01R; they are mounted on pins for lower friction.
Doesn't actually have the Propshaft you spoke of.
C.A.R.
