RE: motor and esc will these do??
Can I suggest going for an ESC with a Motor limit of around 15Turns??
The Tamiya Sports Tuuned is a 23 Turn motor with Fixed Bell Housing and 11 Degress of Advancement...
Whilst Your Choice in Motor is Great for Drift, it isnt a Rebuildable motor..
I mean Sure they are Cheap enough to Throw away once the Brushes are gone but a Better motor with replaceable Brushes wouldnt cost that much more..
Make Sure Your Choice of ESC has the Following:
15 Turn Motor Limit (So you can Run a 19x2T motor Safely)
Reverse ( Reverse is Needed in Drift as you quite often are out of Control to be in control So Revrse will get you outta some sticky places)
