motor and esc will these do??
this is the esc details?
Mtroniks VIPER ECO 27 turn LIMIT RC speed control - brand new
The series consists of forwards only, reversible & marine spec controllers handling every job you can expect from the latest state of the art technology.
NEW built in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers receivers)
**INDUSTRY FIRST**
ABSOLUTE short circuit and motor overload protection
27 turn motor limit
Dual core microprocessor
4-8 cells input voltage
Adjustable features include programmable punch on the forwards only range and programmable reverse (including disable) & programmable brakes on the reversible range
4 Layer super power circuit board
Thermal integrated protection system
Digital one touchset up
Legendary 100% waterproof design
Dimensions : L39.0mm x W34.0mm x H13.0mm
Weight : 55g
All VIPER ESCs are capable of running up to 4500mAh cells & the latest high spec motors. Each VIPER ESC incorporates the latest state of the art technology and GEN-Xi power FETs!
this is the motor??
Tamiya RS-540 Sport Tuned Motor, Part No. 53068 (OP-68)
well guys can i have your opinions please?
**INDUSTRY FIRST**
27 turn motor limit
Weight : 55g
this is the motor??
Banned
Can I suggest going for an ESC with a Motor limit of around 15Turns??
The Tamiya Sports Tuuned is a 23 Turn motor with Fixed Bell Housing and 11 Degress of Advancement...
Whilst Your Choice in Motor is Great for Drift, it isnt a Rebuildable motor..
I mean Sure they are Cheap enough to Throw away once the Brushes are gone but a Better motor with replaceable Brushes wouldnt cost that much more..
Make Sure Your Choice of ESC has the Following:
15 Turn Motor Limit (So you can Run a 19x2T motor Safely)
Reverse ( Reverse is Needed in Drift as you quite often are out of Control to be in control So Revrse will get you outta some sticky places)
