RCU Forums - View Single Post - Balsa Nova 120 ARF Help Needed.
Old 09-16-2006 | 09:06 PM
Tim Taylor
Default RE: Balsa Nova 120 ARF Help Needed.
The wing manual for the Balso Nova 40 is available on the Morris Hobbies website. I believe it's the same build as the big Balsa Nova. I used it when I had a couple questions about the wing. The Fuselage is a piece of cake. If you have any arf experiance you can build it without instructions. Also when I did my review I added a couple hints that might be useful. The review is on the Morris Hobbies website now. One thing that had me stumped for about three minutes was the fuel tank. It wouldn't go in upright or upside down. It took a few minutes to figure out it goes in sideways. Just turn the stopper so the exaust pressure port is up. Another helpfull hint would be on the Pull Pull cables. Push the cable through the crimp three times before crimping it and then add a drop of epoxy. I didn't pull it through three times on my Big Boy and almost lost the plane because of it. I took it apart and re-did the crimps.
ID:	525268   Click image for larger version
