RCU Forums - View Single Post - Is this do-able
Old 09-17-2006 | 02:35 AM
SeacretsOceanCity's Avatar
SeacretsOceanCity
Default RE: Is this do-able
ORIGINAL: Rcpilet
ORIGINAL: SeacretsOceanCity
Hey thanks, I see what you mean.Im going to my LHS Monday to get a prop hub,Then figure how to mount it to a fire wall
The bolts that connect the two halfs together is how I want to mount it , just get longer bolts 3 ''in or so to a mounting plate.
So much info here its hard to sort I have about 3 hours reading in two days learned alot so far Thanks again.
There's lots of guys right here on RCU who will machine you a prop hub for not a lot of money. You just need to know how long you want it and figure out a way to get the right taper on it. Best thing to do--find a guy with a lathe who is willing to make it for $15 or $20 and then sned him the engine so he can measure the taper and get it right.
Ok you lost me here (Taper) where does it have to taper? besides that you gave me a alot better understanding, both you guys THanks.
