WHen do I apply decals
When is a good time to apply the decals? Should I put one clear coat on first, then apply, and shoot the remaining clear coats AFTER??
Also, when you put the decals on, do you guys use something like windex to allow you some working time for the larger decals so they will slide around?
Doing this will force you to wait 2-3 days for the windex to completely dry.
Also, do you sand the final coat with say, 1500 before applying the clear to smooth it out some?
