RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
WHen do I apply decals
Old 01-12-2003 | 01:08 PM
Default WHen do I apply decals
When is a good time to apply the decals? Should I put one clear coat on first, then apply, and shoot the remaining clear coats AFTER??
Also, when you put the decals on, do you guys use something like windex to allow you some working time for the larger decals so they will slide around?
Doing this will force you to wait 2-3 days for the windex to completely dry.
Also, do you sand the final coat with say, 1500 before applying the clear to smooth it out some?
Old 01-12-2003 | 11:24 PM
Default Now we're rolling
I got the decals on ok without the windex. A little luck and help from my wife. I would guess I can clear right away, or should I wait?
I am also wondering, do you scuff the decals a little with say, 500 grit paper so that the clear will stick to them, or should I not worry about that?
Old 01-13-2003 | 01:26 AM
I would wipe the decals down with a bit of wax and grease remover. This is to get any finger prints off and allow the clear to shick better. If there is any wax on the decals you will get fish eyes (the clear will bead up)
