RCU Forums - View Single Post - Twitches
Thread: Twitches
Old 09-17-2006 | 12:27 PM
Craig B.
Default RE: Twitches
Your antenna location is likely to be the problem. I would definitely go with a nose mounted whip antenna. With you antenna running along the fuselage, its reception will be weakest when the model is pointing towards you. You may be comounding the problem if you are pointing the antenna of your transmitter at the model (bad idea!!) as the transmitter's signal is weakest along the long axis of the antenna.
Hope this helps.
Craig.
