RE: re-monokoting a Tower Kaos ARF
heat guns wrok well.
heat the entire surface you want to remove and start at a seam, slowly pull the covering off and reheat areas as needed. any remnants of the old covering can be removed by lightly sanding with a fine sandpaper.
